Dear All,
I have a question
Can ACR9000 control AC30 position?
Hello Binh. Apologies for the late response. No, the ACR9000 should not be used to control position with an AC30. In general, the AC30 should not be used in positioning applications.
The reason is that the AC30 was designed primarily for induction motor control and will simply not give you the responsiveness needed by a position control system.
Hi Daniel Cliffe,
Thank you for your answer
