Hello colleagues,
We have a situation related to 30KW inverters Parker AC10 , software version 3.32. The trouble is, these devices indicate fault on relay output (F300 = 1) when inverter actually goes to SLEEP (PID function).
AC10 with an older firmware (e.g. 2.31) does not indicate SLEEP as fault on a relay output. How do we overcome this situation? SLEEP stage of PID function is not fault and should not be indicated as such.
Off topic: Moderators, can you please advise how do I get permission to ask in Electromechanical support group?
Best regards,
