Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Servo Motor Hi-Flex Cables
Compumotor offers flexible cable options for the SM, BE and NeoMetric Series brushless servo motors with "MS" or "TQ" style connectors. The part numbers listed below replace standard cables in applications that require continuous flexure of the cable. The motors themselves are simply ordered with the "MS" or "TQ" connector option. Please note that this cable does not feature our standard cable design of yellow jacket and color coding. A connection diagram is shipped with each motor providing pertinent information.
Hi-Flex Cables for SM, BE, NeoMetric and J Series Motors
DescriptionCable DiameterMinimum Bend RadiusNo. of CyclesPart Number
SM16 / SM23 / BE16 / BE23 MS Motor Cable0.524 (in.)4.192 (in.)8.92 Mil.71-016023-xx1
N070 / N034 / J034 / J070 / BE34 MS Motor Cable0.4543.6328.92 Mil71-016529-xx
N092 / J092 MS Motor Cable0.6465.1688.92 Mil.71-016530-xx
SM / N070 / N034 / J070 / J034 / BE TQ Motor Cable20.4413.52810.46 Mil.71-017677-xx
SM / N0 / J0 / BE MS Encoder Cable20.3943.15210.46 Mil.71-016022-xx
SM / N0 / J0 / BE MS Resolver Cable0.3502.810.46 Mil.71-016374-xx
1The "xx" is the length of the cable in feet. Lengths are 10, 25, 35, 50 unless otherwise noted.
2The maximum length is 35 feet.
Application Considerations
  • Test Conditions
    • travel distance = 18 feet
    • acceleration = varied up to 26 feet/sec2
    • temperature range during test = +10deg C to +22 deg C
    • speed of travel = varied from 6.5 to 13 feet per second
Use of Cable Carriers
  • Ensure that there are no twists, bends, or kinks in the cable.
  • Lay out the cable for two hours to dissipate any stress from storage, shipping.
  • Allow spacing of at least 10% of cable diameter between cables.
  • Use separators between cables.
  • Do not weave cables amongst other cables.
  • Cables must lay loosely and must be able to move freely within carrier.
  • Distribute cable weight evenly, heavier cables placed toward the outside of the carrier.
  • Do not clamp or tie-wrap cables to carrier itself.
  • Cycle carrier several times before tightening cable clamps, external to carrier, to ensure freedom of movement.
  • Finally, tighten external cable clamps on both ends to maintain proper cable position within carrier.
