Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Servo Motor Cable Diameters & Bend Radii
Listed below is a chart of the minimum bend radii of our motor cables. All cables have brake leads is applicable.
APEX SERIES MOTORS
Cable Cable Diameter Bend Radius
602-606 Motor Cable 0.35" 3.5"
605-606 Motor Cable* 0.36" 3.6"
610-630 Motor Cable 0.40" 4.0"
635-640 Motor Cable 0.40" 4.0"
610-640 Motor Cable* 0.45" 4.5"
Resolver Cable 0.16" 1.6"
Resolver Cable* 0.33" 3.3"
* These cables are used when connecting to a Gemini drive.
SM SERIES MOTORS
16 / 23 Frame Motor Cable (10) 0.31" 3.1"
16 / 23 Frame Encoder Cable (10) 0.34" 3.4"
16 / 23 Frame Motor Cable (TQ) 0.38" 3.8"
16 / 23 Frame Encoder Cable (TQ) 0.4" 4"
16 / 23 Frame Motor Cable (MS) 0.31" 3.1"
16 / 23 Frame Encoder Cable (MS) 0.31" 3.1"
23 Frame Resolver Cable (MS) 0.29" 2.9"
16 / 23 Frame Motor Cable (PS) 0.37" 3.7"
16 / 23 Frame Encoder/Resolver Cable (PS) 0.34" 3.4"
BE SERIES MOTORS
16 / 23 / 34 Frame Encoder Cable (10) 0.34" 3.4"
16 / 23 / 34 Frame Motor Cable (TQ) 0.38" 3.8"
16 / 23 / 34 Frame Encoder Cable (TQ) 0.40" 4.0"
16 / 23 / 34 Frame Motor Cable (MS) 0.35" 3.5"
16 / 23 / 34 Frame Encoder Cable (MS) 0.31" 3.1"
23 / 34 Frame Resolver Cable (MS) 0.29" 2.9"
34 Frame Motor Cable (PS) 0.40" 4.0"
16 / 23 / 34 Frame Encoder/Resolver Cable (PS) 0.34" 3.4"
NEOMETRIC / J-SERIES MOTORS
34 / 70 Frame Motor Cable (10) 0.31" 3.1"
34 / 70 Frame Encoder Cable (10) 0.34" 3.4"
34 / 70 Frame Motor Cable (TQ) 0.38" 3.8"
34 / 70 Frame Encoder Cable (TQ) 0.29" 2.9"
34 / 70 Frame Motor Cable (MS) 0.35" 3.5"
34 / 70 Frame Encoder Cable (MS) 0.31" 3.1"
34 / 70 Frame Resolver Cable (MS) 0.29" 2.9"
34 / 70 Frame Motor Cable (PS) 0.37" 3.7"
34 / 70 Frame Encoder/Resolver Cable (PS) 0.34" 3.4"
92 Frame Motor Cable (MS) 0.43" 4.3"
92 Frame Encoder Cable (MS) 0.31" 3.1"
92 Frame Resolver Cable (MS) 0.29" 2.9"
92 Frame Motor Cable (PS) 0.4" 4"
92 Frame Encoder/Resolver Cable (PS) 0.34" 3.4"
M SERIES MOTORS
105-Frame Motor Cable 0.48" 4.80"
145-Frame Motor Cable 0.65" 6.50"
205-Frame Motor Cable 0.71" 7.10"
M105 / 145 / 205-Frame Resolver Cable 0.325" 3.25"
M105 / 145 / 205-Frame Encoder Cable 0.32" 3.2"
Please see the HI-FLEX Cable FAQ for information on Hi-Flex Cables.
