Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base CTC and i-Motors
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
CTC and i-Motors
Parker iBE motors are compatible with Parker Powerstations using the ASCII driver. An example of this implementation is available on our website at:
iBEExamp.zip
Wiring diagram for RS485 connection:
upd rar 6/30/2012
  • iBEE
  • INTERACT
  • PA
  • I-Motor
  • PA2
