Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Transformer Specs
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
Transformer Specs
Below are the specs for all of the transformers that have been offered from Compumotor as stand-alone products. Multiple voltages are available on one secondary winding. The voltages available for one winding are separated by a "/" and separate winding voltages are separated by a comma. Secondary currents are the maximum for that winding no matter the voltage used.
Transformer Part NumberTypical Drive Power Rating (kVA)Primary Voltage (Vrms) Secondary Voltage (Vrms) Max Output Secondary Current (Arms)
TO3310732110 - 24086,114*
TO64CD0.6110 - 24061/40, 2011, 1.4
TO73CD & BL301.2110 - 48061/40, 2020, 3
TO81*2160 - 48086, 86/114, 10/110, 10/11010, 10, 0.7, 0.7
TO87*0.5110 - 48086, 206, 1.4
TO89*1.2110 - 48086, 86, 207, 7, 3
TO9010732160 - 48086, 86/114, 10/110, 10/11010, 10, 0.7, 0.7
TO92CD & BL300.6110 - 48061/40, 2011, 3
TO116SD2, 3, 50.1110 - 24026/183.8
TO119SD2, 3, 50.3110 - 24026/1811.5
TO120SD2, 3, 50.45110 - 24026/1817
TO122SD20.05110 - 240192.6
TO124HD & PKH2.5110 - 480172, 172, 115, 187, 7, 0.3, 2.75
TO132HD1.26110 - 480172, 115, 187, 0.2, 2
TO138UD2, 5, 120.5110 - 24018, 18/27/40/611, 7.5
TO139UD2, 5, 121110 - 24018, 18, 18/27/40/612, 11, 11
TO142PKC Toroid0.3110 - 24061/40, 194.5, 1.6
TO149HD, PKH, PK1302.5110 - 480115, 107, 18*
TO150HD, PKH, PK651.2110 - 480115, 107, 18*
TO165SYS7, BD1402.5208 - 41514/71/99/127, 120, 18/189, 1, 3
TO166SYS7, BD1405208 - 41514/71/99/127, 120, 18/1818, 2.5, 6
TO170SYS7, BL1.2110 - 480107, 11511 , 1
TO171SYS7, BL2.5110 - 480107, 11522, 1
TO181UD12, CD60, CD802.6110 - 480107/86, 115, 1822, 1, 3
TO182UD12, CD60, CD801.4110 - 480107/86, 115, 1811, 1, 3
TO185SYS7, UD12, CD60, CD802.5208 - 415127/99/71/14/7, 120, 18/189, 1, 3
TO186SYS7, UD12, CD60, CD805208 - 415127/99/71/14/7, 120, 18/1818, 2.5, 6
TO193SD12, 13, 150.3110 - 24044/186.8
TO194SD12, 13, 150.6110 - 24044/1813.6
* Information unavailable
