Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SM Motors - SM Flexible Cable Wiring Diagram
Here is the SM Series Flexible Cable Connection Diagram
Motor Cable: P/N 71-016023-xx Resolver Cable,P/N 71-016374-xx
Designation Pin No.MS14-12 Wire Color Designation Pin No.MS14-18 Wire Color
PhaseA J Red #1 S1,Cos+ E Black
PhaseB K Red#2 S2,Sin+ L Green
PhaseC L Red#3 S3,Cos- J Red
Ground M Green/Yellow S4,Sin- G Blue
Reserved* G Red#5 R1,EXC+ C Brown
Reserved* H Red#6 R2,EXC- U White
*Temp Connection for Encoder Motors
Temp N Yellow
Temp R Gray
Reserved - Pink
Reserved - Violet
Encoder/Hall Feedback Connection
ENCODER CABLE:p/n 71-016022-xx
Encoder
VCC H Red
Ground G Black
CH A+ A White
Ch A- B Yellow
CH B+ C Green
CH B- D Blue
Index + E Pink
Index - F Brown
Hall GND K White/Green
Hall 5+ M Gray/Pink
Hall 1 T White/Brown
Hall 2 U Red/Blue
Hall 3 P Violet
Brake R White/Yellow
Brake S Brown/Yellow
Temp L White/Gray
Temp N Brown/Gray
