Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Visual Basic Sample with AT Card
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
Here is a sample flow diagram of how to can check if motion has stopped on a particular axis. The example is for an AT product under Visual Basic 4.0 environment.
Using the "Fast Status" capability of the AT6400 you may check a bit in a register. This bit will tell you if your motor is moving or not. A good idea would be to create a subroutine that waits for your motor to stop moving. Check Chapter 2 of the "6000 Series Programer's guide" for more details.
A sample is written below. The steps are as follows:
Step 1
Make a function that returns a TRUE if the motor is currently moving and a FALSE if the motor is not moving. Call the function IsMoving(....)
Arguments: Axis
This argument specifies which axis to check for motion.
Return Values: Boolean
TRUE if specified Axis is moving.
FALSE otherwise.
Step 2
Make a subroutine that waits for motion to stop. Call the subroutine WaitForMove(.....)
Arguments:Axis
Same as above.
Sample Program follows:
Public Function IsMoving(ByVal Axis As Integer) As Boolean
Dim status_high As Integer
Dim status_low As Integer
Dim status As Long
Dim Temp As Integer
Select Case Axis
Case 1
Temp = request_status(Address)
Call set_pointer(Address, AXIS1_STATUS)
Call read_status(Address, status_high, status_low, status)
IsMoving = status And 1 'Mask out all bit so that only bit one remains
Case 2
Call set_pointer(Address, AXIS2_STATUS)
Case 3
Call set_pointer(Address, AXIS3_STATUS)
Case 4
Call set_pointer(Address, AXIS4_STATUS)
Case Else
IsMoving = False
End Select
End Function
'This subroutine waits for axis to stop moving
Public Sub WaitForStop(ByVal Axis As Integer)
Do Until IsMoving(Axis) = False
Temp = DoEvents()
'have this loop wait
Loop
End Sub
Now if you start a motion on axis 1 just call the WaitForStop(1) funtion and it will wait until all motion has stopped.
Example:
Call MakeMove(1) 'make axis 1 move
Call WaitForStop(1) 'wait until axis one has stopped moving.
