Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SM Motors - SM Series 23 Connection Diagram
Here is the SM Series Size 23 Connection Diagram
Motor Connection Resolver connection
Designation Pin No . MS14-12 Wire Color Designation Pin No . MS14-18 Wire Color
PhaseA J Red/Yellow S1,COS+ E Black
PhaseB K White/Yellow S2,SIN+ L Green
PhaseC L Black/Yellow S3,Cos- J Red
Ground M Green/Yellow S4,Sin- G Blue
Temp* G Orange/Yellow or Yellow(T) R1,EXC+ C Brown
Temp* H Orange/Yellow or Yellow(T) R2,EXC- U White
Shield NC Temp R Yellow/Orange
HALL Feedback or TQ Connection Option
Temp N Yellow/Orange
Hall effect
Brake S Red/Blue
Hall GND F White/Green Brake T Red/Blue
Hall 5+ B White/Blue
Hall 1 C White/Brown
Hall 2 D White/Orange
Hall 3 E White/Yellow or White/Violet
Encoder/Hall Feedback Connection
ENCODER/HALL FEEDBACK CONNECTION
Designation Pin No.MS14-18 Wire Color
Encoder
VCC H Red
Ground G Black
CH A+ A White
Ch A- B Yellow
CH B+ C Green
CH B- D Blue
Index + E Orange
Index - F Brown
Hall-effect(Not applicable for "TQ" option
Hall GND K White/Green
Hall 5+ M White/Blue
Hall 1 T White/Brown
Hall 2 U White/Orange
Hall 3 P White/Violet
Brake R Red/Blue
Brake S Red/Blue
