Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AC690+ Series (Discontinued)
  • AC/DC Industrial Drives-
    • Legacy/Discontinued Products-
      • AC690+ Series (Discontinued)-
        • What replaces the 690+?
        • What are the basic wiring connections to run a motor?
        • How to Install and Extract Parameters from a 690+ Drive?
        • 690+ Modbus TCP/IP Addressing with the Ethernet Techbox
        • 690+: Is the keypad detachable during operation?
        • 690+: What are the minimum and maximum 3-phase input voltage ratings?
        • 690:+ System Board Terminals
        • Can the 690+ be used in a load sharing application?
        • Can the 690+ be used in a Phase Move application?
        • Can the 690+ be used in a registration application?
        • Can the 690+ be used in an Electronic Lineshaft application?
        • Can the 690+ Switch Between Speed and Torque Mode?
        • Can you download a DSELite file into the 690+ drive when the drive is running?
        • Frame B 690+ differences?
        • How can the 690+ be configured?
        • How can the 690+ drive configuration be reset to factory defaults?
        • How do I choose/what are the default configurations for the 690+?
        • How do I flash my 690+ drive to newer Firmware?
        • How do I know what firmware revision my 690+ is?
        • How does the Inverse Time (Overload) functionality protect the drive (690)?
        • How much I/O is available on the 690+?
        • How to Clone the 690+ Drive
        • Is there any additional information on troubleshooting 690+ and AC890 Frame K drives?
        • The 690+ bus voltage is extremely high on power up. Why?
        • The 690+ is enabled, and START is true, but the motor runs slow with high torque. Why?
        • What are part numbers for the Frame B 690+?
        • What are the Communication options for the 690+?
        • What are the reference power supplies available to terminal connections on the 690+?
        • What are the types of Speed Feedback for the 690+?
        • What is the current overload rating for the 690+ drive?
        • What is the maximum operating altitude for the 690+?
        • What is the operating temperature for the 690+?
        • What is the output frequency of the 690+?
        • What options can be added to the 690+?
        • What safety standards does the 690+ meet?
        • What USB-serial adapter should I use? (copy)
        • Why am I getting a speed feedback error?
        • Why am I getting over-voltage trips?
        • Why does my motor run hot?
        • Why is my current reading wrong or running unstably on my F frame 690+?
        • Why won't my 690+ inverter run my motor?
        • 690+ - Transferring a Configuration to a Drive with a Different Power Level
        • AH467407U001 encoder card - use 6054-00 when ordering
        • How do I convert AC690+ Europe part numbers to US part numbers?
        • What are the differences between Chassis/Panel mount, Wall mount, and Thru-Panel mount in the 690+ (690P) family?
        • WHAT DOES "NET FAIL" INDICATE IN DSE LITE WHEN USING A LINKNET TECHBOX MODULE ON MY 690+ DRIVE?
      • TS8000, DSI3, & DSI8000 (Discontinued)+
      • 5507 Analog Panel Meters (Discontinued)
      • AC584 Series (Discontinued)
      • DC590 Series (Discontinued)
      • AC620 Series (Discontinued)
      • AC650 Series (Discontinued)
      • What do I replace my AC650 drive with?
      • How can I connect to a 590C or 590D with DSE Lite?
      • L5392 Color LinkStation Information
      • Replacement LINK Fiber Optic Cable
      • What is DSD and LINK?
    • AC15/AC20
    • DESAT (OVER I) Fault
AC690+ Series
[QuickLink for the 690+ on Parker.com] - Manual, QuickStarts, Product Support, etc
  • 690+
