Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Software - Following a Virtual Master
This program is designed to start a motor following a Virtual Master as smoothly as possible.
drive0
axsdef0
drive1
scla25000
sclv25000
scld25000
sclmas25000
scale1
DEL VM
DEF VM
MC1
COMEXC1
FOLRN10
FOLRD1
FOLEN1
FOLMAS+16 ;Axis 1 follows the Virtual Master (VM)
SINGO0 ;Stop the VM.
SINAMP1000 ;Set the VM Amplitude.
FVMACC999999999 ;Set the VM Acceleration to infinity.
FVMFRQ0 ;Set the VM Frequency to zero.
SINGO1 ;Start the VM.
T1 ;Wait a bit just to make sure the VM Frequency
; gets to zero in case it didn't start at zero.
SINANG0 ;Set the VM Angle to zero.
FVMACC10 ;Set the VM Acceleration to really low.
T.005 ;Wait a little bit before starting to follow.
GO1 ;Start following.
FVMFRQ3600 ;Increase VM Frequency to desired value.
T1 ;Wait a moment before increasing the VM Acceleration.
FVMACC1000 ;VM Acceleration can be adjusted as desired.
END
Setting the Frequency to zero with the FVMFRQ0 command does not
occur instantaneously. If the FVMFRQ has previously been set to
a higher value, then the Frequency will go to zero by the
Acceleration rate of FVMACC.
Note that the Follower is not started until after the Virtual
Master is started. But, the FVMFRQ is not increased until
after the GO1, so there will not be any position lost. Doing
it any other way creates a little bump...as of Version 5.1.1 of
the 6K Operating System.
