Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Software - Example program for general motion
The sole purpose of this sample program is to illustrate
; the operation of setting up the 6k to get 1 revolution
; of motion for a servo and stepper axis.
; It is the responsibility of the user to
; insure the program is not misused
; This program assumes that HARD LIMITS ARE NOT BEING USED.
; This program assumes that tuning for the servo axis has been done,
; If not use the default values for SGP,SGV, SGI AND SGILIM
SCLD4000,25000 ;set the distance to 1 rev for axis 1&2
SCLV4000,25000 ;set the velocity to 1 rev/sec for axis 1&2
SCLA4000,25000 ;set the acceleration to 1 rev/sec^2 for axis 1&2
SCALE1 ;enable scaling
DEL MOTION ;delete motion program
DEF MOTION ;define motion program
DRIVE00 ;disable axis 1&2
AXSDEF10 ;define axis 1 as servo axis and axis 2 as a stepper axis
DRES,25000 ;set the drive resolution of axis 2 to be 25000 steps/rev
ERES4000 ;set the encoder resolution of axis 1 to be 4000 counts/rev
LH0,0 ;disable hardware limits for axis 1&2
COMEXS1 ;save command buffer on stop
COMEXC0 ;disable continuous execution mode
MC00 ;disable mode continuous
MA00 ;set axis 1&2 to incremental distance mode
A10,10 ;set the acceleration on axis 1&2 to be 10 rev/sec^2
V1,1 ;set the velocity on axis 1&2 to be 1 rev/sec
D1,1 ;set the distance on axis 1&2 to be 1 rev
DRIVE11 ;enable drives on axis 1&2
GO11 ;initiate motion on axis 1&2
END
