Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interrupts, AT cards & troubleshooting
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
Here is a procedure to troubleshoot whether the interrupts work on AT cards or not depending on IRQ setting you have choosen.
1. Set the dip switches on the AT card to the interrupt you desire to use. Make sure that it does not conflict with other interups that are currently being used by other devices on your computer.
2. Go to Motion Architect and choose your AT card product. Enter Terminal Mode.
3. Disconnect from terminal mode
4. Click on terminal and set the IRQ values under the settings (PC-AT interrupt menu) to match to the values you set on the dip switches.
5. Download the operating system. Then type the following commands in terminal mode:
intw.25-1 ;enables timer interupt
timint0,4000 ;sets the timer for every 4 seconds.
timst0 ;start the timer
You should get a message on terminal screen telling you that the card is sending interupts. If you do not receive any message then select another dip switch setting and go to step 2. To stop the timer use the command:
timstp ;stop the timer
