Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Misc - What size Compact Flash card is supported by XPR/XPC?
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
Prior to version 2.04 our XPR/XPC images only supported up to 512MB of storage.
Currently, our XPR/XPC images based on Windows CE image support storage devices up to 4GB (either CF or USB drive)
The CF card MUST be a bootable card - which can be difficult to find in commercial channels.
