Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR Servo Tuner - Move Back & Forth sample code
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
For quick sample code to move back and forth for Servo Tuning in ACR-View:
DRIVE ON X
DWL .2
RES X
DWL .1
ACC 100
DEC 100
STP 100
VEL 10
X/10
INH -516
DWL .2
X/-10
