Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to Simulate Motion (without drives or motors)?
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
If you want to simulate motion without enabling axes and command motion, run the programs normally but don't enable the drives.
The scopes in ACR-View can be used to display the secondary setpoint (Axis Parameters > Position Parameters > Secondary Setpoint, ie P12295 for Axis0).
