Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Custom Products
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
Custom Products
Custom step motor and electronics part numbers begin with CP*, such as CP*S106-178-12102 is a custom S106-178 step motor. Apex servo motors, Dynaserv motors/drives, electronics and accessories also are customized with CP* as a prefix.
If you would like to purchase a replacement, contact your local Parker Automation Technology Center distributor that can request these online on our extranet.
If needing to get a motor, drive or controller repaired, you may contact your local Parker Automation Technology Center distributor or the machine builder for repair RMAs.
CP*APEX605-MO-NC
CP*APEX605-MO-NC-B
CP*APEX606-MO-NC-B
CP*APEX606MO-12444
CP*APEX606MO-12843
CP*APEX606P-MO-NC
CP*APEX610-MO-NC
CP*APEX610MO-NC-SL
CP*APEX615-12866
CP*APEX615-14194
CP*APEX6154
CP*APEX6154-9807
CP*APEX620-MO-9657
CP*APEX620-MO-9658
CP*APEX620-13024
CP*APEX620MO-12450
CP*APEX620MO-12493
CP*APEX620MO-13255
CP*APEX635-MO-NC-B
CP*SY561T-13971
CP*SY563T-13999
CP*SY872L-14943
CP*SY872T-13378
CP*SY873T-IP-13819
CP*S106-178-MO
CP*S106-178-14691
CP*S106-178S-14584
CP*S106-205-MO-E
CP*S106-205-MO-25
CP*S106-250-MO
CP*S106205MO-13849
CP*S57-102-MO-25
CP*S57-102MO-12942
CP*S57-102MO-13112
CP*S57-102MOE-10699
CP*S57-102NC-12707
CP*S57-51-MO-12871
CP*S57-51MO-12923
CP*S83-135-MO-25
CP*S83-135MO-10494
CP*S83-135MO-12130
CP*S83-93-M-E-W303
CP*TS32B-12809
CP*TS41B-MO-11100
CP*TS42B-DKP-13178
CP*VS31B-12911
CP*VS32BK-E-12696
CP*LV142-02-13486
CP*LV171-02-10-EC
CP*LV173-02-10-EC
CP*LV231-FLM-14055
CP*LV231-01-14350
CP*LV231-01-14351
CP*LV231-02-10-EC
CP*LV231-02-14350
CP*LV231-02-14351
CP*LV231-02FL-ROHS
CP*LV231EC20-14036
CP*LV232-01-13604
CP*LV232-02-10-EC
CP*LV232-02-13261
CP*LV233-EC-14662
CP*LV233-02-10-EC
CP*LV233-02-14349
CP*LV341-02-10-EC
CP*LV342-02-FL-EC
CP*LV342-02-10-EC
CP*LV343-02-FL-EC
CP*LV343-02-10-EC
CP*HV171-1-10-IP65
CP*HV171EC40-14302
CP*HV173-02-10-EC
CP*HV231-01-10IP65
CP*HV231-02-13249
CP*HV231-02-14438
CP*HV232-01-10IP65
CP*HV232-01-20
CP*HV232-02-10-EC
CP*HV232EC40-14234
CP*HV2320210-13490
CP*HV233-01-10IP65
CP*HV233-01-14035
CP*HV233-02-10-EC
CP*HV233-02-13308
CP*HV233-02-14441
CP*HV341-FL-14101
CP*HV341-HT-14909
CP*HV341-01-50
CP*HV341-02-10-EC
CP*HV341-02-12481
CP*HV342-02-10-E
CP*HV342-02-10-EC
CP*HV342EC20-14946
CP*HV343-02-10-EC
CP*HV343-02-14439
CP*DRG3-1015B-230A
CP*DRG3-1060-13223
CP*DRG3-1070E-230A
CP*DRG3-1130-13476
CP*DRG3-5030-13201
CP*DRG3-5030B-2-50
CP*DRG3-5500A-200
CP*DRG31008B-13918
CP*DRG310081-10256
CP*DRG31070E-10256
CP*DRG3108B1-14881
CP*DRG3108MO-14883
CP*DRG31100E-14827
CP*DRG31200A-14443
CP*DRG35015C-14703
CP*DRG35015C-14740
CP*DRG35030B-14951
CP*DRG5015CM-12813
CP*DR1045B-14841
CP*DR11302DO-13476
CP*DR31008DO-13918
CP*DR3110EMO-10256
CP*DR5030B-MO-9729
CP*DMG3-1004-13275
CP*DMG3-1015-13091
CP*DMG3-1015-13187
CP*DMG3-1015-13200
CP*DMG3-1045-14158
CP*DMG3-1100-13563
CP*DMG3-13600
CP*DMG31004-13339
CP*DMG31004B-14492
CP*DMG31004C-13636
CP*DMG31004MO13636
CP*DMG31015B-14169
CP*DMG31045B-13638
CP*DMG31045B-13816
CP*DMG31050A-14150
CP*DMG31150A-14561
CP*DMG31200-13654
CP*DM1B004F-13702
CP*DM1B015-14614
CP*DM1B045G-13701
CP*DM1050-MO-12495
CP*DM1100AMO-13693
CP*GPDM-14686
