Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I set the frequency in an ACR SINE move?
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Frequency = VEL/(2 * PI * AMP)
So to get a desired frequency, set VEL = frequency * 2 * PI * AMP
where
VEL = Master Velocity
PI = 3.14
AMP = Amplitude specified in the SINE command
keywords: sinusoidal
3/28/12 glh
