Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I download software from www.parkermotion.com?
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
The main Parker-EMN website is www.parkermotion.com and the primary software download page is located at http://www.parkermotion.com/scripts/support_downloads.asp.
If you have never registered at the parkermotion website it will require you to register to be able to download any of the free software tools or product operating systems.
If you have registered before but the registration page appears, only fill in your registered email address at the top of the page (none of the other fields) to login.
Possible problems with the registration page
The common problem is getting returned to the registration page again after submitting.
  • Auto Fill inserts your name/address and your email address at the top. This forces the registration page to try to re-register the same email address which it will not do.  If you have auto-fill turned on, turn it off and reload the webpage (F5) and type in only your email at the top.
  • Registration page requires 'cookie' support in your browser.
  • Administration rights are required on your local system/network to allow for downloads.
  • All required fields must be filled in. All fields that are bold are required.
For old MTS product software, the download page is located at this site instead:
http://www.parkermotion.com/new_ulm/downloads_current.htm
For old CTC legacy product software, the download page is found here:
http://www.ctcusa.com/Support/support.asp
If problems registering, email emn.service@support.parker.com and include screen capture of your registration page.
New users registering should look like this:
Returning users should look like this:
