Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Variable data types and transfer to AB plc via Ethernet/IP
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Products: ACR9000, 9030, 9040, 9600, 9630, 9640, Aries Controller (AR-xxCE)
ACR controller user parameters/variables are listed below:
Note user parameters P0 - P4095 are 64-bit floats. If using Ethernet/IP to transfer data to these variables from an Allen Bradley/Rockwell plc:
CIP Class1 messages data transmitted to the PLC with always be represented as DINT data type regardless of the actual data sent.
example:  If p1=10.0 on the ACR it will show as hex 4120000 on the PLC.
Use COP function to move this from the HEX/DINT form into a real to convert it to 10.0
For further details:
Direct Variables Applications Note
