Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Connector Part Numbers
Product C2 Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No. PCD Part No.
GV & GT All Versions 43-016913-01 Yes 1 CONN, 4P, BLACK KEEP ALIVE/RELAY   ELFT04260E
GV6-DN & GT6-DN N/A No 1 CONN, 5P, GREEN DEVICENET 1757048
