Product | C2 Connector Part Number | Available for Purchase? | Quantity per Drive | Description | Function | Phoenix Part No. | PCD Part No. | Weidmuller Part No. |
Zeta4 | 43-008755-01 | Yes | 1 | CONN, 9P, BLACK | MOTOR POWER | 1764361 | ELFT09250C | |
Zeta8 | 43-013575-01 | Yes | 1 | CONN, 7P, BLACK | MOTOR POWER | 1838242 | ||
Zeta12 | 43-013575-01 | Yes | 1 | CONN, 7P, BLACK | MOTOR POWER | 1838242 | ||
Zeta4-240 | 43-013575-01 | Yes | 1 | CONN, 7P, BLACK | MOTOR POWER | 1838242 | ||
OEMZL4 | 43-008755-01 | Yes | 1 | CONN, 9P, BLACK | MOTOR POWER | 1764361 | ELFT09250C | |
Zeta4 & OEMZL4 | 58-011555-01 | Yes | 1 | RUBBER BOOT | MOTOR POWER | |||
Zeta6104 (With V_I/O) | 43-008755-01 | Yes | 1 | CONN, 9P, BLACK | MOTOR POWER | 1764361 | ELFT09250C | |
43-013891-01 | Yes | 1 | CONN,10P, 3.5 MM, BLACK | I/O | 161020 | |||
43-013969-01 | Yes | 2 | CONN, 4P, 3.5 MM, BLACK | LIMITS & COM1 | 161569 | |||
43-014707-01 | Yes | 1 | CONN, 5P, 3.5 MM, BLACK | COM2 | 161409 | |||
43-014708-01 | Yes | 1 | CONN, 9P, 3.5 MM, BLACK | ENCODER | 161571 | |||
OEMZL6104 | 43-008755-01 | Yes | 1 | CONN, 9P, BLACK | MOTOR POWER | 1764361 | ELFT09250C | |
58-011555-01 | Yes | 1 | 9-PIN RUBBER BOOT | MOTOR POWER | ||||
OEMZL6106 | 43-013891-01 | Yes | 1 | CONN,10P, 3.5 MM, BLACK | I/O | 161020 | ||
Zeta6104 (Without V_I/O) | 43-008755-01 | Yes | 1 | CONN, 9P, BLACK | MOTOR POWER | 1764361 | ELFT09250C | |
43-014708-01 | Yes | 2 | CONN, 9P, 3.5 MM, BLACK | ENCODER & I/O | 161571 | |||
Zeta6108 | 43-013575-01 | Yes | 1 | CONN, 7P, BLACK | MOTOR POWER | 1838242 | ||
58-011555-01 | Yes | 1 | 9-PIN RUBBER BOOT | MOTOR POWER (Old versions) | ||||
58-016135-01 | Yes | 1 | 7-PIN RUBBER BOOT | MOTOR POWER (New versions) | ||||
Zeta6112 | 43-013575-01 | Yes | 1 | CONN, 7P, BLACK | MOTOR POWER | 1838242 | ||
58-016135-01 | Yes | 1 | 7-PIN RUBBER BOOT | MOTOR POWER | ||||
Note: ZETA6104 are listed twice because the Zeta6104 originally did not have a V_I/O pin. These would be very old units (before October 2, 1997, which is 97100200500 serial number). Everything after has the V_I/O pin.
