Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - What are the voltage specifications for the analog inputs?
The absolute limits for the analog inputs is -15V to +35V.
5/7/12 glh
