Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Can the Compax3 Drives Share the DC Bus Connection?
The Compax3 servo drives can share the DC bus ONLY if they have the same model number.
If your drives have different model numbers, please install a ballast resistor for regen instead.
