Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Accessories - Connector Part Numbers
Product C2 Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No. PCD Part No. Weidmuller
Part No.
6Kn 43-017555-02      No   CONN,PLUG,12PIN,.2" CONTROLLER POWER   ELFF1224S1C
6Kn-DN N/A No 1 CONN, 5P, 5.08 MM, GREEN DEVICENET 1757048
6250 43-005561-01       Yes 1 CONN,5P,PLUG,BLACK RP240 1741821 ELFT05250C
  43-008755-01 Yes 6 CONN,9P,PLUG,SMOOTH,BLACK DRIVES, ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
  43-011995-01        Yes 2 CONN,7P,PLUG,BLACK  AUX, COM1, TRIGGERS 1764345 ELFT07250C
  43-011905-01      No 1 CONN,3P,A/C,PLUG  AC POWER 1741834 ELFT04250C
6200 43-005561-01       Yes 1 CONN,5P,PLUG,BLACK RP240 1741821 ELFT05250C
  43-008755-01 Yes 3 CONN,9P,PLUG,SMOOTH,BLACK DRIVES, ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
AT6250 43-008755-01 Yes 9 CONN,9P,PLUG,SMOOTH,BLACK DRIVES, ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
AT6200 43-005560-01          Yes 1 CONN,4P,PLUG,BLACK,BR TRIGGERS 1741834 ELFT04250C
  43-008755-01 Yes 4 CONN,9P,PLUG,SMOOTH,BLACK ENCODERS, LIMITS, AUX 1764361 ELFT09250C 25.345.3953.1
AT6450 43-008755-01 Yes 13 CONN,9P,PLUG,SMOOTH,BLACK DRIVES, ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
AT6400 43-008755-01 Yes 8 CONN,9P,PLUG,SMOOTH,BLACK DRIVES, ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
AT6n50 ANI OPTION 43-011995-01        Yes 1 CONN,7P,PLUG,BLACK  AUX, COM1, TRIGGERS 1764345 ELFT07250C
6201 43-008755-01 Yes 3 CONN,9P,PLUG,SMOOTH,BLACK ENCODERS, LIMITS 1764361 ELFT09250C 25.345.3953.1
  43-010262-01 No 2 CONN,7P,PLUG,FRONT LOAD MOTOR POWER 1784406 ELFF07240C
