Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Accessories - Connector Part Numbers for Older Model PS-60W
Product C2 Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No.
PS-60W (OLDER PHOENIX) 43-013290-01 No 1 CONN,3P,.300,PLUG,PHNX INPUT AC VOLTAGE 1766893
    No 1 CONN,2P,.300,PLUG,PHNX OUTPUT DC VOLTAGE 1766880
