Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 9000: Connector Part Numbers
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
ACR9000: Connector Part Numbers
Product Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No. PCD Part No.
ACR9000 43-021606-01 Yes 1 CONN,2P,FLNG MNT Motion Enable Input   ELFP02210E
