Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Connector Part Numbers
Product C2 Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No.
C3 S025, S063 088-032595 No* 1 CONN, 3P, PHOENIX, 5.08 mm X1 AC POWER 1777992
  088-033105 No* 1 CONN, 5P, PHOENIX, 5.08 mm X2 RESISTOR 1825349
  088-033106 No* 1 CONN, 6P, PHOENIX, 5.08 mm X3 MOTOR POWER 1825352
  088-032710 No* 1 CONN, 5P, PHOENIX, 5.08 mm X4 DC POWER & ENABLE 1778014
* Part of ZBH 02/01 Connector kit which is available for purchase
C3 S038, S075, S100, S150 088-033512 No** 1 CONN, 4P, PHOENIX, 7.62 mm X1 AC POWER 1828265
  088-033511 No** 1 CONN, 5P, PHOENIX, 7.62 mm X2 RESISTOR 1828278
  088-033509 No** 1 CONN, 6P, PHOENIX, 7.62 mm X3 MOTOR POWER 1828281
  088-032710 No** 1 CONN, 5P, PHOENIX, 5.08 mm X4 DC POWER & ENABLE 1778014
** Part of ZBH 02/02 Connector kit which is available for purchase
C3 S300 088-033604 No*** 1 CONN, 4P, PHOENIX, 10.16 mm X1 AC POWER 1913594
  088-033605 No*** 1 CONN, 5P, PHOENIX, 10.16 mm X2 RESISTOR 1913604
  088-033606 No*** 1 CONN, 6P, PHOENIX, 10.16 mm X3 MOTOR POWER 1913617
  088-032710 No*** 1 CONN, 5P, PHOENIX, 5.08 mm X4 DC POWER & ENABLE 1778014
*** Part of ZBH 02/03 Connector kit which is available for purchase
