Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Aries drive won't enable
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
If the Aries drive does not enable when connected and there is no fault on the Aries drive, check that the ACR9000 to Aries cable is connected with the end labelled Controller into the ACR9000 and the end labelled Aries into the amplifier.  The axis light on the ACR9000 flickers momentarily but the drive does not enable.  This is noted on a label on the controller end of the cable but easily overlooked. Having these reversed does not damage the drive. Power-down before correcting the cable connection.
