Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base DX Motors- Servo Wheel weights (discontinued product)
Approximate weight, includes tires and mounting brackets which may be optional:
6" Servo WheelTM
without brake   16 lbs.
with brake        18 lbs.
8" Servo WheelTM
without brake    20 lbs.
with brake         22 lbs.
