Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What verison of the .Net Framework is needed for ACR-View 6?
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
ACR-View 6.x requires either .NetFramework 1.1 or 3.51 (or higher).
The installer for Version 6.1 only checks for Framework 1.1 and flags the user if this was not installed.
This has been updated in the installer for ACR-View 6.2 which now checks for either 1.1 or 3.51+. If missing, the installer will prompt the user to install 3.51(or higher).
Framework 4.x includes everything that 3.51 has. Most Win7 PCs include 4.x, so there is generally no need to add 3.51 when installing ACR-View 6.2 on a Windows 7 PC.
When using Windows7 (32 or 64-bit) we recommend that you use 6.2 as that includes Windows signatures and checks for the later versions of the .NetFramework.
jan 31 2012  JW
