Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Software - How to wrap text on a tool in Xpress Manager?
    • Interact (Legacy)+
    • Interact Xpress-
    • IXA / PCA+
1-Feb-2012
Product: Interact Xpress
When adding text to a panel tool, the text will be one continous line. In order to get the text to start on a new line, use Ctrl+Enter keys while editing.
