Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Specs - Mounting Kit Standard Motor Shaft Diameters
  • Gearheads-
Below are the standard motor shaft diameter ranges for each series and frame size Parker Bayside gearhead.  We can accommodate slightly larger maximum shaft diameters than the ones shown by boring the input pinion on the gearhead to fit the larger motor shaft size.  This operation requires a custom gearhead quote, which needs to be requested by your Parker Technology Center (distributor).
Model Numbers                          Minimum Dia. [mm]                      Maximum Dia. [mm]
PS/PX/RS/RX 60                                            5                                                        14
PS/PX/RS/RX 90                                          6.35                                                    19
PS/PX/RS/RX 115                                        9.53                                                    24
PS/PX/RS/RX 142                                      15.88                                                    32
PS/RS 180                                                   15.88                                                   48
PS/RS 220                                                     24                                                       55
PV40/PV17                                                    3                                                         9
PV60/PV23                                                  6.35                                                    14
PV90/PV34                                                    8                                                        19
PV115/PV42                                                 11                                                       24
