Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Cables - MOK Motor Power and GBK or REK Feedback Cables
Compax3 cables are manufactured by Parker Electromechanical Europe. Below drawings are from the Compax3 user guide. For full specs, contact Parker EME at em-motion@parker.com or see the website http://www.parker-eme.com/ For price quote & delivery, contact your local Parker ATC distributor for a custom product quote on our extranet. These are offered for re-sale only in North America. For new applications, use motors shown on http://www.parkermotion.com
To see the cable pinouts, click on text below.
GBK23/xx.....Compax3 - Encoder cable, xx meters
GBK24/xx.....Compax3 - MH / SMH SinCos© cable, high flex, xx meters
GBK38/xx.....Compax3 - MH / SMH EnDat cable, high flex, xx meters
GBK56/xx.....Compax3 - Endat 2.2 cable.  Contact factory at em-motion@parker.com
REK42/xx.....Compax3 - MH / SMH Resolver cable, xx meters
REK41/xx.....Compax3 - MH / SMH Resolver cable, high flex, xx meters
MOK54/xx.....SMH / MH56 / MH70 / MH105, 13.8A, high flex, xx meters
MOK55/xx.....SMH / MH56 / MH70 / MH105, 13.8A, xx meters
MOK56/xx.....SMH / MH56 / MH70 / MH105, 18.9A, xx meters
MOK57/xx.....SMH / MH56 / MH70 / MH105, 18.9A, high flex, xx meters
MOK59/xx.....MH145 / MH205, 18.9A, xx meters
MOK60/xx.....MH145 / MH205, 13.8A, xx meters
MOK61/xx.....MH145 / MH205, 32.3A, high flex, xx meters
MOK62/xx.....MH145 / MH205, 47.3, high flex, xx meters
MOK63/xx.....MH145 / MH205, 13.8A, high flex, xx meters
