Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Output Reaction to EPL Failure
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
Onboard outputs of the AriesEPL drives on an EPL network failure will turn off. When the EPL is re-connected, the outputs will be re-asserted.
Onboard outputs of the Compax3EPL drives on an EPL network will remain set.
With the Parker I/O, CanBus lifeguarding will cause outputs to turn off if the Can network fails.
