Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR Binary Parameter Access Examples
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
Supplement to ACR Programmers Guide,Binary Host Interface
Products: ACR9000,9030,9040,9600,9630,9640, AR-xxCE (Aries Controlller)
Binary parameter access provides a method of reading from and writing to single system parameters on the controller. Unlike binary data packets, binary parameter access uses the actual parameter number. There are no groups or masks.
A parameter access header consists of a Header ID ( 0x00 ) followed by a Packet ID code and a 2-byte parameter. The Packet ID codes for the different types of packets are shown below. The following pages define each of the packets in detail.
Packet ID Codes
Code Packet Type Description
0x88 Binary Get Long Receive long integer from controller
0x89 Binary Set Long Send long integer to controller
0x8A Binary Get Float Receive Float value from controller
0x8B Binary Set Float Send Float value to controller
When using the Binary Parameter Access, the parameter is converted to hex. The parameter is a 2-byte value sent low-order byte first. Here are some examples:
P12288(current position, axis0) converts to 30 00. Request is sent to controller as 00 88 00 30
P12546(actual position, axis1) converts to 31 02. Request is sent to controller as 00 88 02 31
P8193(vector velocity) converts to 2001.  Request is sent to controller as 00 8A 01 20
VB.Net example for formatting the byte packets
Imports System.BitConverter
PublicFunction GetLongPacket(ByVal iParm AsInteger) As System.Array
Dim bArr(3) As Byte
Dim byteParm(1) As Byte
bArr(0) = &H0
bArr(1) = &H88
byteParm = BitConverter.GetBytes(iParm)
System.Array.Copy(byteParm, 0, bArr, 2, 2)
Return  bArr
End Function
23-Mar-2012
