Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base LV/HV Motors - Replacements for the VS series step motors
  • Step Motors-
    • A/AX Motors - A vs M motors
    • LV/HV Motors - Customs
    • VS Motors - Motor Cables
03-March-2012
Products: VS Step Motor, HV Step Motors
VS series Step Motors were retired per Bulletin # SB701 Date: Friday, April 28, 2006.
The HV motors replace the VS motors. See the chart below for the suggested part number replacement. In most cases, the performance of the HV motor meets or exceeds the performance of the VS motor. Slight mounting differences are also noted in the chart. As with all replacement situations, the application needs to be evaluated to determine if the suggested replacement product will work.
VS motor
Mounting Differences
VS12B-SNFLY
HV171-01-FL
1
VS12B-DNFLY
HV171-02-FL
1, 2
VS12B-SNR10
HV171-01-10
1
VS12B-DNR10
HV171-02-10
1, 2
VS13B-SNFLY
HV172-01-FL
1
VS13B-DNFLY
HV172-02-FL
1, 2
VS13B-SNR10
HV172-01-10
1
VS13B-DNR10
HV172-02-10
1, 2
VS21B-SFFLY
HV231-01-FL
3, 4
VS21B-DFFLY
HV231-02-FL
3, 4
VS21B-SFR10
HV231-01-10
3, 4
VS21B-DFR10
HV231-02-10
3, 4
VS22B-SFFLY
HV232-01-FL
3, 4
VS22B-DFFLY
HV232-02-FL
3, 4
VS22B-SFR10
HV232-01-10
3, 4
VS22B-DFR10
HV232-02-10
3, 4
VS23B-SFFLY
HV233-01-FL
3, 4
VS23B-DFFLY
HV233-02-FL
3, 4
VS23B-SFR10
HV233-01-10
3, 4
VS23B-DFR10
HV233-02-10
3, 4
VS31B-SFFLY
HV341-01-FL
5
VS31B-DFFLY
HV341-02-FL
5
VS31B-SFR10
HV341-01-10
5
VS31B-DFR10
HV341-02-10
5
VS32B-SFFLY
HV342-01-FL
5
VS32B-DFFLY
HV342-02-FL
5
VS32B-SFR10
HV342-01-10
5
VS32B-DFR10
HV342-02-10
5
Mounting Differences:
1
HV17 motor has a round front shaft, VS1_ motor has a flat
2
HV17 motor rear shaft length = 0.39", VS1_ motor rear shaft = 0.59"
3
HV23 motor front shaft length = 0.81", VS2_ motor front shaft = 0.79"
4
HV23 pilot depth = 0.06", VS2_ pilot = 0.03"
5
HV34 rear shaft length = 1.13", VS3_ rear shaft = 1.34"
