Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - What are the height dimensions of the Parker Style PS connectors?
Dimensions below are rounded UP to the nearest millimeter.  Pictures show the dimension being measured.
Motor connector height from feedback housing is 27mm
Feedback connector height from feedback housing is 24mm
PS-CONN-KIT, connector dimensions:
Motor (pn 43-021659-01):
Feedback (pn 43-021660-01):
Connector heights with PS-CONN-KIT assembled to motor connectors:
Motor = 85mm
Feedback = 65mm
JE 03/28/12
UPDATED JME 12/12/12
