Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Misc - How do I know if I have a Bayside Single or Double Stage Gearhead?
  • Gearheads-
If your gear ratio is 10:1 or less, you have a single stage gearhead.
If your gear ratio is greater than 10:1, you have a double stage gearhead.
The different overall lengths for single and double stage gearheads are listed in the Bayside catalogs as L1 and L2 respectively.
JE 03/28/12
