Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - MPP motor right angle PS connector dimensions
Although the general length and height dimensions of the MPP right angle PS motor connectors can be deduced indirectly from the drawings in the MPP catalog/brochure, the following are the length and height dimensions in mm[inches] for convenience:
Size 1 motor connector (MPP092-142):
Size 1.5 motor connector (MPP190-270):
Feedback connector (All):
JE 03/28/12
UPDATED JE 04/26/13
