Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Range Error on download for IF ENDIF statements
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
In the memory section of ACR-View, do not set Number of Defines to 0, where the default is 20. This needs to be set to a non-zero value for IF ENDIF syntax to be valid. Single line IF THEN is not affected. Setting this to 0 disables IF ENDIF as valid syntax and will cause a Range Error on download.
