Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is a Moving Segment Error?
      • 9000 (Legacy)+
      • IEC PLC (9600) (Legacy)-
        • PLCOpen State Machine
        • Using arrays in IEC PLC
Products: ACR9600, 9630,9640
When loading a Program to the PLC by going online, you may get the Error message:
Loading the program will be aborted. You will still be online with the PLC, so "upload error log"
This will place a txt file in the PLC Brower:
Open the file to see the error:
Possible errors:
Error ID
Message
Reason
Example
1
ACR flag range error Flag:
flag number does not exist on ACR
MyBool : Bool AT%B99999
2
ACR flag drive I/O Flag:
drive I/o flags
MyBool : Bool AT%BW70
3
Restricted Flags (see list below)
MyBool : Bool AT%BW8468
4
ACR parameter not dimensioned Parameter:
Global Vars not dimensioned
MyReal : REAL AT%P200;
5
ACR parameter range error Parameter:
parameter number does not exist on ACR
MyReal : REAL AT%P99900
The following flags CANNOT BE ASSIGNED AS AT%BW (read/write), a Moving Segment Error will result.
These bits can still get set thru the PLC, using MC_WriteBoolParameter or ACR_WriteFlag
Bit Range
Desc
ErrorID
768
1023
Primary Axis Flags (Axes 0-7)
3
7680
7935
Primary Axis Flags (Axes 8-15)
3
512
767
Primary Master Flags (Masters 0-7)
3
40
47
Drive Enable Outputs
2
48
55
Drive Reset Outputs
2
56
63
LEDs
2
64
71
Drive Fault Inputs
2
96
103
LEDs
2
112
115
Trigger captures
3
JW 2012
