Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base EPL Velocity p38145 vs p8193 Master Velocity
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
EPL Velocity        p38145 Axis0 (read-only)
Signed change in EPL drive's encoder counts since the previous servo period.
This parameter is in encoder counts per servo period.
If needing a parameter per seconds use:
Vector Velocity      p8193 Master0 (read-only)
This is the current total vector velocity of all the axes attached to the master. It is always positive and varies between zero and user set velocity (VEL).
edited 4/9/12 - rr
