Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Whats the difference between FLH-0512P and FLH-0512?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
FLH-0512-P is the part number for the 512MB compact flash card for the CTC legacy products, or any unit running INTERACT. (This includes PA/P13/PA2)
FLH-0512 is the part number for the 512MB compact flash card for units running Interact Xpress or InteractX ONLY. The Interact flash back utilities will not support this card.
Last Modified 3/27/2012 by KJAX
