Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can I run Interact7 on my Windows 10 or 7 PC?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
All versions of Interact, including Interact 7, are NOT compatible with Win10 or Win7 or XP compatibility mode within Windows7 for development purposes.
A computer running Windows XP is required.
A virtual PC such as Oracle Virtualbox or VMWare running Windows XP will work with Interact version 7. MachineShop is the overall package of MachineShop Toolbar Project manager and upload/download utility manager. Interact is also included in it.
Runtime is MSDOS and only runs on the HMI hardware.
Last Modified DM 06/17/19
