Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base NM Motors - NM17 NM23 NM34 NM42 Servo Motor Specifications
The NM series servo motors are obsolete. These were a housed frameless kit motor; we can provide housed kit motors as custom. Contact your local Parker Automation Technology Center distributor for a price quote for custom servo motors.
Click here for the Bayside/MFM catalog specs for the NM series servo motors.
jh 4/10
part numbers
NM17-050-001
NM17A-7710
NM17A-8530-001
NM17A-EX31-001
NM17X-1.50-4238
NM23-28300
NM23A-1410
NM23A-2130
NM23A-2430
NM23A-DG10
NM23A-DG10-001
NM23A-E930
NM23A-EG10
NM23A-EG30
NM23A-GG80
NM23X-0.50-3095
NM23X-0.50-4666
NM23X-1.50-2922
NM23X-1.50-3340
NM23X-1.5-1057
NM34A-7811
NM34A-8831
NM34A-DF10
NM34A-DG10
NM34A-EE30
NM34A-EE40
NM34X-0.50-3334
NM34X-0.5-67461
NM34X-050-82639
NM34X-1.00-2781
NM34X-1.00-3340
NM34X-1.00-4330
NM34X-1.50-2719
NM34X-1.50-2720
NM34X-1.50-3270
NM34X-1.50-3708
NM34X-1.50-3784
NM34X-1.50-5596
NM34X-1.50--5596
NM34X-1.50-5599
NM34X-1.50-6092
NM34X-1.5-5596
NM34X-150-5596
NM34X-3.00-4079
NM42-050-003
NM42-12100
NM42-2.00-5427
NM42A-7610
NM42A-LH30
NM42A-LK40
NM42A-LL30
NM42E-2.00-5427
NM42E-2.00-5427
NM42X-150-85339
NM42X-2.00-5427
NM42X-2.00-5709
NM42X-2.00-5936
NM42X-2.50-5443
