Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I transfer my old Interact application to a newer Interact panel?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
If the replacement panel is the same part number as the original HMI panel, users can simply remove the Compact Flash (CF) card from the original unit and place it in the replacement unit.
If the models are different, the project will need to be transferred via Interact software, but no changes will need to be made.
The following document outlines the procedure to follow if you need to upload your application files from an existing legacy Interact power station panel and then download to your newer Interact power station panel.
Interact Project Transfers
Rock Interface, a long time Parker Automation Technology Center and CTC channel partner has created this video that steps you through this upgrade.  Thanks Rock!
Our ATCs have engineers on staff to help you with upgrades and new machine needs and are a valuable resource with engineering expertise.
3/30/12 glh
6/11/13 kj
7/18/22jh video added
