Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Accessories - BRM Braking Resistor Information
Compax3 Available Braking Resistor Overview:
Ballast resistor Device Rated output
BRM08/01 (100 OHMS) Compax3S025V2 60 W
Compax3S015V4
Compax3S038V4
BRM05/01 (56 OHMS) Compax3S063V2 180 W
Compax3S075V4
BRM05/02 (56 OHMS) Compax3S075V4 570 W
BRM10/01 (47 OHMS) Compax3S150V4 570 W
BRM10/02 (470 OHMS) Compax3S150V4 1500 kW
BRM04/01 (15 OHMS) Compax3S150V2 570 W
Compax3S300V4
PSUP20D6
BRM04/02 (15 OHMS) Compax3S150V2 740 W
Compax3S300V4
PSUP20D6
BRM04/03 (15 OHMS) Compax3S300V4 1500 W
PSUP20D6
BRM09/01 (22 OHMS) Compax3S100V2 570 W
BRM11/01 (27 OHMS) Compax3H0xxV4 3500 W
BRM13/01 (30 OHMS) PSUP10D6 500 W
PSUP20D6**
BRM14/01 (15 OHMS) PSUP10D6* 500 W
BRM12/01 (18 OHMS) Compax3H1xxV4 4500 W
*for PSUP10D6 2x15W in series
**for PSUP20D6 2x30W parallel
For informaion on Compax3 external braking resistors, type in the keywords "external braking resistors" into C3 ServoManager Help Index files.
"Permissable braking pulse power" curves allows calculation of cooling cycle times for given braking resistor and input power.
Dimensional information of each braking resistor is also in the help files.
BRM Specifications Sheets
JE 04/09/12
