Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What replaces Compumotor 34frame gearmotors?
The Compumotor integrated gearmotors are obsolete and no longer available. For replacements, the Stealth Gen II PX34 servo class gearbox is a very close replacement.
Performance comparison:
Dimensional comparison:
Torque comparison:
Custom PX34-L2 with larger output shaft diameter similar to the dual-stage Size 34 gearhead would be rated at 98Nm acceleration torque for 20:1, 25:1, 50:1, 70:1
*Custom PX34 available with lower backlash for high accuracy applications.
Note that the motors and gearheads are purchased as separate items:
1. BE343JJ-NGSN.....Servo Motor
2. PX34-010-L2.........Inline PX34 Stealth Gen II gearhead, 10:1 ratio low backlash
2. MU90-005.............Mounting kit
The MU90-005 is the mounting kit for both the BE34 and N034 or J034 motors.
The G05 was a 5.5:1 ratio, G22 22:1 ratio, G55 55:1 ratio. The Stealth has as standard 5:1, 20:1, 25:1 and 50:1 (exact ratios). The 5.5:1, 22:1 and 55:1 ratios could be done as custom.
Longer shafts to match the previous gearmotor and/or the Woodruff key are also available as custom.
The above is summarized based on catalog specifications. However, application requirements may be different; the PV34 value line gearhead could also be considered.
As reference for Compumotor Gearmotor catalog specs:
Compumotor Gearmotors
The integrated gearmotors have the pinion machined into the motor shaft and thus cannot be disassembled and the motor re-used with the new gearheads.
