Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Accessories - IPA as Ethernet/IP Scanner for Ethernet/IP I/O Adapter Devices (Video)
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
The IPA can now be used with Wago Ethernet/IP expansion IO for applications needing more inputs & outputs. The total limits are 64 bytes of digital inputs, 64 bytes of digital outputs, 32 analog input points, and 32 analog input points.
IPA can only be slave to one device and scanner for one device.
Here's a sample program to do this: click here.
Click here for: IPA Bus coupler Start Up manual
The manual includes screen captures of the Wago module webpage and how to configure it, as well as an explanation of the new commands, parameters and bits.
Note the IPA needs to have firmware version: 4.42 or higher
ACR-View version 6.4.1 has updated Status Panels (Numeric and Bit Status) that include the Ethernet/IP information for the IPA.
 IPA as Ethernet/IP Scanner with Wago 750-352 - YouTube  (newer Wago version is the 750-363)
How to setup Wago Ethernet/IP Bus coupler for use with IPA - YouTube
ACR-View Numeric & Bit Status panels updated showing Ethernet/IP Scanner status:
Note: Wago 750-341 was replaced by Wago 750-352. Both will work with the IPA (newer Wago version is the 750-363).
10/5/16jh
